If you want to have more information on AI Endpoints, please read the following blog post.
You can, also, have a look at our previous blog posts on how use AI Endpoints.
You can find the full code example in the GitHub repository.
In this article, we will explore how to use structured output with OVHcloud AI Endpoints.
Introduction to Structured Output
Structured output allows you to format output data in a way that makes it easier for machines to interpret and process.
We use the langchain4j library to interact with OVHcloud AI Endpoints.
Here is an excerpt of code that shows how to define a structured output format for the responses of the language model:
ResponseFormat responseFormat = ResponseFormat.builder()
.type(ResponseFormatType.JSON)
.jsonSchema(JsonSchema.builder()
.name("Person")
.rootElement(JsonObjectSchema.builder()
.addStringProperty("name")
.addIntegerProperty("age")
.addNumberProperty("height")
.addBooleanProperty("married")
.required("name", "age", "height", "married")
.build())
.build())
.build();In this example, we define a JSON output format with a schema that specifies the name, age, height, and married properties as required.
Configure the model to use
This example uses the Mistral AI model hosted on OVHcloud AI Endpoints.
To configure the model, you need to set up the API key, base URL, and model name as environment variables.
Fell free to use another model, see AI Endpoints catalog.
You can find your access token, model URL, and model name in the OVHcloud AI Endpoints model dashboard.
ChatModel chatModel = MistralAiChatModel.builder()
.apiKey(System.getenv("OVH_AI_ENDPOINTS_ACCESS_TOKEN"))
.baseUrl(System.getenv("OVH_AI_ENDPOINTS_MODEL_URL"))
.modelName(System.getenv("OVH_AI_ENDPOINTS_MODEL_NAME"))
.logRequests(false)
.logResponses(false)
.build();Calling the language model
Thanks to the JSON mode of the LLM, the response from the language model is received as a JSON string:
UserMessage userMessage = UserMessage.from("""
John is 42 years old.
He stands 1.75 meters tall.
Currently unmarried.
ChatRequest chatRequest = ChatRequest.builder()
.responseFormat(responseFormat)
.messages(userMessage)
.build();
ChatResponse chatResponse = chatModel.chat(chatRequest);
String output = chatResponse.aiMessage().text();
System.out.println("Response: \n" + output);
// Person is a simple record: record Person(String name, int age, double height, boolean married) {}
Person person = new ObjectMapper().readValue(output, Person.class);
System.out.println(person);The full source code
///usr/bin/env jbang "$0" "$@" ; exit $?
//JAVA 21+
//PREVIEW
//DEPS dev.langchain4j:langchain4j:1.0.1 dev.langchain4j:langchain4j-mistral-ai:1.0.1-beta6
import com.fasterxml.jackson.databind.ObjectMapper;
import dev.langchain4j.data.message.UserMessage;
import dev.langchain4j.model.chat.request.ChatRequest;
import dev.langchain4j.model.chat.request.ResponseFormat;
import dev.langchain4j.model.chat.request.ResponseFormatType;
import dev.langchain4j.model.chat.request.json.JsonObjectSchema;
import dev.langchain4j.model.chat.request.json.JsonSchema;
import dev.langchain4j.model.chat.response.ChatResponse;
import dev.langchain4j.model.mistralai.MistralAiChatModel;
import dev.langchain4j.model.chat.ChatModel;
void main() throws Exception {
.name("Person")
.build())
.build())
.build();
.build();
.logRequests(false)
.build();
System.out.println("Prompt: \n" + userMessage.singleText());
}Running the application
jbang HelloWorld.java
[jbang] Building jar for HelloWorld.java...
Prompt:
Response:
{"age": 42, "height": 1.75, "married": false, "name": "John"}
Person[name=John, age=42, height=1.75, married=false]This code example uses JBang, a Java-based tool for creating and running Java programs as scripts.
For more information on JBang, please refer to the JBang documentation.
In this article, we have seen how to use structured output with OVHcloud AI Endpoints with LangChain4J.
You have a dedicated Discord channel (#ai-endpoints) on our Discord server, see you there!
