Back
LLMs streaming with AI Endpoints and LangChain4j
Have a look at our previous blog posts:
- Enhance your applications with AI Endpoints
- How to use AI Endpoints and LangChain4j
After explaining how to use AI Endpoints and LangChain4j in the previous post, let's take a look at how to use streaming to create a real chat bot !
Create the project with Quarkus
Like the previous post about AI Endpoints we'll use LangChain4j through a Quarkus extension: quarkus-langchain4j.
ℹ️ All the code source used in the blog post is available on our GitHub repository: public-cloud-examples/ai/ai-endpoints/quarkus-langchain4j-streaming ℹ️
First of all, you need to create a Quarkus application with the Quarkus CLI.
bash
quarkus create app com.ovhcloud.examples.aiendpoints:quarkus-langchain4j-streaming \
    --extension='quarkus-langchain4j-mistral-ai,rest'
ℹ️ For more details on the type of files are created, see the blog post How to use AI Endpoints and LangChain4j ℹ️
AI Service creation
LLM is used remotely via a LangChain4j AI Service.
Let’s code our service to create a chat bot.
java
package com.ovhcloud.examples.aiendpoints.services;
import dev.langchain4j.service.SystemMessage;
import dev.langchain4j.service.UserMessage;
import io.quarkiverse.langchain4j.RegisterAiService;
import io.smallrye.mutiny.Multi;
@RegisterAiService
public interface ChatBotService {
  // Scope / context passed to the LLM
  @SystemMessage("You are a virtual, an AI assistant.")
  // Prompt (with detailed instructions and variable section) passed to the LLM
  @UserMessage("Answer as best possible to the following question: {question}. The answer must be in a style of a virtual assistant and add some emojis.")
  Multi<String> askAQuestion(String question);
If you want more information about the purpose of SystemMessage and UserMessage you can read the documentation of the Quarkus extension.
Then, you have to configure the quarkus-langchain4j extension to use AI Endpoints.
bash
### Global configurations
# Base URL for Mistral AI endpoints
quarkus.langchain4j.mistralai.base-url=${OVH_AI_ENDPOINTS_MODEL_URL}
# Activate or not the log during the request
quarkus.langchain4j.mistralai.log-requests=true
# Activate or not the log during the response
quarkus.langchain4j.mistralai.log-responses=true
# Delay before raising a timeout exception
quarkus.langchain4j.mistralai.timeout=60s
# No key is needed
quarkus.langchain4j.mistralai.api-key=${OVH_AI_ENDPOINTS_ACCESS_TOKEN}
# Activate or not the Mistral AI embedding model
quarkus.langchain4j.mistralai.embedding-model.enabled=false
### Chat model configurations
# Activate or not the Mistral AI chat model
quarkus.langchain4j.mistralai.chat-model.enabled=true
# Chat model name used
quarkus.langchain4j.mistralai.chat-model.model-name=${OVH_AI_ENDPOINTS_MODEL_NAME}
# Number of tokens to use
quarkus.langchain4j.mistralai.chat-model.max-tokens=1024
ℹ️ To know how to use the OVHcloud AI Endpoints product, please read the blog post: Enhance your applications with AI Endpoints ℹ️
AI chat bot API
Now it’s time to test our AI!
Let’s develop a small API.
java
package com.ovhcloud.examples.aiendpoints;
import com.ovhcloud.examples.aiendpoints.services.ChatBotService;
import jakarta.inject.Inject;
import jakarta.ws.rs.POST;
import jakarta.ws.rs.Path;
@Path("/ovhcloud-ai")
public class AIEndpointsResource {
    // AI Service injection to use it later
    @Inject
    ChatBotService chatBotService;
    // ask resource exposition with POST method
    @Path("ask")
    @POST
    public Multi<String> ask(String question) {
        // Call the Mistral AI chat model
        return chatBotService.askAQuestion(question);
Call the API with a curl command.
bash
curl http://localhost:8080/ovhcloud-ai/ask\?question\=%22Can%20you%20tell%20me%20what%20OVHcloud%20is%20and%20what%20kind%20of%20products%20it%20offers\?%22
And that it!
In just a few lines of code, you’ve developed your first chat bot using Quarkus, LangChain4j and AI Endpoints.
This chat bot use the streaming mode, fell free to develop a web application to be more usable by humans 😉.
Don’t hesitate to test our new product, AI Endpoints, and give us your feedback.
You have a dedicated Discord channel (#ai-endpoints) on our Discord server (https://discord.gg/ovhcloud), see you there!
Share on:
