Back
Create encrypted Persistent Volumes on OVHcloud Managed Kubernetes clusters with LUKS
Since this summer, it's possible to create encrypted OVHcloud Block Storage with OMK (OVHcloud managed key) in RBX, SBG, Paris & BHS regions. More regions will come in the coming months 💪.
And the good news is that you can use encrypted Block Storage using Persistent Volumes in your OVHcloud Managed Kubernetes Service (MKS) clusters 🎉.
In this post, we’ll show you how to encrypt persistent volumes on an OVHcloud Managed Kubernetes (MKS) cluster using a csi-cinder-high-speed-gen2-luks Storage Class. Leveraging LUKS-based encryption at the storage layer, you’ll learn how to protect your data at rest without sacrificing the performance of NVMe-backed volumes.
We’ll guide you step by step: defining the Storage Class, creating a Persistent Volume Claim (PVC), and deploying a Pod that mounts the encrypted volume.
This practical walkthrough is designed for developers and platform engineers looking to secure their Kubernetes workloads on OVHcloud in a straightforward way.
How to
You will create a Persistent Volume Claim (PVC), linked to a Storage Class, that will automatically create a Persistent Volume (PV) that will automatically create an associated encrypted Public Cloud Block Storage volume.
Then you will create a Pod attached to the PVC.
Let’s create an encrypted Persistent Volume in our OVHcloud MKS cluster
Prerequisite: Have an OVHcloud MKS cluster.
First, create a csi-cinder-high-speed-gen2-luks.yaml file with the following content:
💡 Note that if you deploy in on a MKS 1AZ cluster (instead of my 3AZ MKS cluster), you should define the volumeBindingMode to Immediate instead.
yaml
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
allowVolumeExpansion: true
parameters:
  fsType: ext4
  type: high-speed-gen2-luks
provisioner: cinder.csi.openstack.org
reclaimPolicy: Delete
volumeBindingMode: WaitForFirstConsumer
This StorageClass is using the same configuration as existing csi-cinder-high-speed-gen2 but with the high-speed-gen2-luks type.
So the result will be the usage of SSD disks with NVMe interfaces encrypted with LUKS (Linux Unified Key Setup) which is a standard on-disk format for hard disk encryption.
Apply the manifest file:
bash
kubectl apply -f csi-cinder-high-speed-gen2-luks.yaml
⚠️ You can't modify the volumeBindingMode value for an existing Storage Class, you have to delete it and create a new one.
List the Storage Classes in the cluster:
bash
$ kubectl get sc
NAME                              PROVISIONER                RECLAIMPOLICY   VOLUMEBINDINGMODE      ALLOWVOLUMEEXPANSION   AGE
csi-cinder-high-speed (default)   cinder.csi.openstack.org   Delete          WaitForFirstConsumer   true                   33d
csi-cinder-high-speed-gen-2       cinder.csi.openstack.org   Delete          WaitForFirstConsumer   true                   33d
csi-cinder-high-speed-gen2-luks   cinder.csi.openstack.org   Delete          WaitForFirstConsumer   true                   4s
Create a pvc-luks.yaml file with the following content:
yaml
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 10Gi
  storageClassName: csi-cinder-high-speed-gen2-luks
Create a new namespace and apply the manifest file into it:
bash
kubectl create ns test-pvc-luks
kubectl apply -f pvc-luks.yaml -n test-pvc-luks
Check the status of our newly created PVC:
yaml
$ kubectl get pvc -n test-pvc-luks
NAME       STATUS    VOLUME   CAPACITY   ACCESS MODES   STORAGECLASS                      VOLUMEATTRIBUTESCLASS   AGE
pvc-luks   Pending                                      csi-cinder-high-speed-gen2-luks   <unset>                 3s
$ kubectl describe pvc pvc-luks -n test-pvc-luks
Namespace:     test-pvc-luks
StorageClass:  csi-cinder-high-speed-gen2-luks
Status:        Pending
Volume:
Labels:        <none>
Annotations:   <none>
Finalizers:    [kubernetes.io/pvc-protection]
Capacity:
Access Modes:
VolumeMode:    Filesystem
Used By:       <none>
Events:
  Type    Reason                Age                From                         Message
  Normal  WaitForFirstConsumer  10s (x2 over 10s)  persistentvolume-controller  waiting for first consumer to be created before binding
Status:        Pending
Volume:
Labels:        <none>
Annotations:   <none>
Capacity:
Access Modes:
Used By:       <none>
Events:
As you can see, your PVC have been creating, with the luks Storage Class, and is Pending to be Bound, until the creation of a Pod with a volume (because of the WaitForFirstConsumer value):
Create a pod.yaml file with the following content:
yaml
apiVersion: v1
kind: Pod
metadata:
spec:
  containers:
  - name: nginx
    image: nginx
    volumeMounts:
    - mountPath: "/usr/share/nginx/html"
  volumes:
  - name: encrypted-volume
    persistentVolumeClaim:
      claimName: pvc-luks
bash
kubectl apply -f pod.yaml -n test-pvc-luks
The PVC should now be Bound and a new PV should be created:
bash
pvc-luks   Bound    ovh-managed-kubernetes-siti343p-pvc-3a3b1d2e-ebdf-41a2-8f8f-4ee6984b6149   10Gi       RWO            csi-cinder-high-speed-gen2-luks   <unset>                 3m27s
$ kubectl get pv -n test-pvc-luks
NAME        CAPACITY   ACCESS MODES   RECLAIM POLICY   STATUS   CLAIM                    STORAGECLASS                      VOLUMEATTRIBUTESCLASS   REASON   AGE
ovh-managed-kubernetes-siti343p-pvc-3a3b1d2e-ebdf-41a2-8f8f-4ee6984b6149   10Gi       RWO            Delete           Bound    test-pvc-luks/pvc-luks   csi-cinder-high-speed-gen2-luks   <unset>                          32s
First the Pod should be in ContainerCreating state (waiting the creation and the attachment of the volume) and after few seconds it will be Running:
markdown
$ kubectl get pod pod-with-encrypted-volume -n test-pvc-luks
NAME                        READY   STATUS              RESTARTS   AGE
pod-with-encrypted-volume   0/1     ContainerCreating   0          44s
# Wait a little...
pod-with-encrypted-volume   1/1     Running   0          2m10s
The Pod is now created with an attached volume:
bash
$ kubectl describe pod pod-with-encrypted-volume -n test-pvc-luks
Priority:         0
Service Account:  default
Node:             my-pool-zone-c-h5xjf-7n7kt/192.168.142.174
Start Time:       Tue, 19 Aug 2025 10:10:41 +0200
Labels:           <none>
Annotations:      <none>
Status:           Running
IP:               10.240.0.203
IPs:
  IP:  10.240.0.203
Containers:
  nginx:
    Container ID:   containerd://c38c0a0e19970503ad1bfaa0c74b5cc320cb9df08456c7613b9a9a8c908b9190
    Image:          nginx
    Image ID:       docker.io/library/nginx@sha256:33e0bbc7ca9ecf108140af6288c7c9d1ecc77548cbfd3952fd8466a75edefe57
    Port:           <none>
    Host Port:      <none>
    State:          Running
      Started:      Tue, 19 Aug 2025 10:11:42 +0200
    Ready:          True
    Restart Count:  0
    Environment:    <none>
    Mounts:
      /usr/share/nginx/html from encrypted-volume (rw)
      /var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-vbcnk (ro)
Conditions:
  Type                        Status
  PodReadyToStartContainers   True
  Initialized                 True
  Ready                       True
  ContainersReady             True
  PodScheduled                True
Volumes:
  encrypted-volume:
    Type:       PersistentVolumeClaim (a reference to a PersistentVolumeClaim in the same namespace)
    ClaimName:  pvc-luks
    ReadOnly:   false
  kube-api-access-vbcnk:
    Type:                    Projected (a volume that contains injected data from multiple sources)
    TokenExpirationSeconds:  3607
    ConfigMapName:           kube-root-ca.crt
    ConfigMapOptional:       <nil>
    DownwardAPI:             true
QoS Class:                   BestEffort
Node-Selectors:              <none>
Tolerations:                 node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
                             node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
  Normal   Scheduled               3m48s                  default-scheduler        Successfully assigned test-pvc-luks/pod-with-encrypted-volume to my-pool-zone-c-xxxx-xxxx
  Normal   SuccessfulAttachVolume  3m8s                   attachdetach-controller  AttachVolume.Attach succeeded for volume "ovh-managed-kubernetes-siti343p-pvc-xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
  Normal   Pulling                 2m53s                  kubelet                  Pulling image "nginx"
  Normal   Pulled                  2m48s                  kubelet                  Successfully pulled image "nginx" in 5.072s (5.072s including waiting). Image size: 72324501 bytes.
  Normal   Created                 2m48s                  kubelet                  Created container: nginx
  Normal   Started                 2m48s                  kubelet                  Started container nginx
Logging in the OVHcloud Control Panel, you can see that the encrypted volume have been successfully created:
Finally, you can use your volume.
Execute a shell in the Nginx Pod and create an index.html file into it:
bash
$ kubectl exec -it pod-with-encrypted-volume -n test-pvc-luks -- /bin/bash
root@pod-with-encrypted-volume:/# echo "Hello from OVHcloud encrypted Block Storage!" > /usr/share/nginx/html/index.html
And curl the webserver:
bash
root@pod-with-encrypted-volume:/# apt update
root@pod-with-encrypted-volume:/# apt install curl
root@pod-with-encrypted-volume:/# curl http://localhost/
What's next?
In this blog post we saw a basic (but concrete) usage of the encrypted Persistent Volume on OVHcloud Kubernetes clusters that just bee released, don't hesitate to think about it for your sensitive data.
In the coming months, the encrypted Block Storage will be available worldwide. Follow the Encrypted Block Volumes issue on GitHub to stay informed.
And don't hesitate to take a look to our Cloud Roadmap & Changelog to see the state of all of the coming features in OVHcloud Public Cloud products.
Share on:
