Navigating OVHcloud Enterprise File Storage (EFS) with Trident CSI On Kubernetes clusters (MKS)
If you find yourself in need of shared persistent storage for applications running on OVHcloud Managed Kubernetes Service (MKS), then OVHcloud Enterprise File Storage (EFS) with Trident CSI offers you a practical way to provision and manage it.
This blog post explains how to create and connect OVHcloud EFS to your MKS cluster using Trident CSI, so you can dynamically provision persistent storage for Kubernetes workloads.
OVHcloud Enterprise File System (EFS)
EFS is a high-performance, fully managed file storage solution powered by NetApp ONTAP in an active-active architecture. It is designed for enterprise workloads requiring high availability, predictable performance, and seamless integration with cloud-native environments.
The service is available in multiple regions, including Roubaix, Gravelines, Strasbourg, Limbourg, and Beauharnois, with a strong SLA of 99.99% uptime. Storage capacity ranges from 50 GB up to 29 TB.
EFS delivers guaranteed performance with 4,000 IOPS and 64 MB/s throughput per TiB, scaling linearly with volume size thanks to NVMe SSD infrastructure.
Built for modern infrastructures, EFS integrates natively with Kubernetes via Trident CSI (compatible with MKS) and supports ReadWriteMany (RWX) access. It operates within a single availability zone (1AZ) and provides low-latency NFS storage over OVHcloud’s secure vRack network, ensuring strong security and compliance.
NetApp Trident CSI
Trident is an open-source, fully supported storage orchestration project maintained by NetApp. It is designed to help Kubernetes applications consume persistent storage using standard interfaces such as the Container Storage Interface (CSI).
Trident runs directly inside Kubernetes clusters as a set of Pods and enables dynamic provisioning and management of storage for containerized workloads. It allows applications to easily access persistent storage from NetApp’s ecosystem, including ONTAP systems (like the OVHcloud EFS).
Let’s do it!
EFS creation
We already have a MKS cluster, in GRA11 region, running inside a private network and a subnet, with a gateway.
We also already have a vRack and our Public Cloud Project attached to this vRack.
So in this blog post we will only create a new EFS in eu-west-rbx region, attached to a vRackServices, inside the same subnet that our existing MKS cluster.
Here you can see the architecture of all the services:
⚠️ EFS and MKS regions may differ; be aware that latency between different regions may impact your storage workloads performance. It’s highly recommended to keep your storage and compute as close as possible.
We will deploy the EFS in eu-west-rbx instead of in eu-west-gra region to show you that it is possible.
To deploy the EFS, we will use the Terraform OVHcloud EFS module.
The module we will use can deploy all the components necessary to use EFS with a MKS cluster (like you can see in the schema).
But in this blog post we will assume that we already deployed:
  • a vRack
  • a Private Network
  • a Private Subnet
  • a Gateway
  • a MKS cluster
So using the Terraform module we will fill the existing resources information and ask Terraform to create:
  • an OAuth2 credential
  • an IAM policy
  • an EFS
  • a vRack Services
Let’s deploy our components with Terraform!
Create a provider.tf file and fill it with the information:
terraform {
required_providers {
ovh = {
source = "ovh/ovh"
version = ">= 2.12.0"
null = {
source = "hashicorp/null"
version = ">= 3.0.0"
required_version = ">= 1.7.0"
provider "ovh" {
If you don’t define the provider information inside this file, as was shown in this example, you can instead set the environment variables with your credentials:
# OVHcloud provider needed keys
export OVH_ENDPOINT="ovh-eu"
export OVH_APPLICATION_KEY="xxx"
export OVH_APPLICATION_SECRET="xxx"
export OVH_CONSUMER_KEY="xxx"
export OVH_CLOUD_PROJECT_SERVICE="xxx"
Create a variable.tf.template file and fill it with these information:
# Existing services
variable "service_name" {
default = "$OVH_CLOUD_PROJECT_SERVICE"
variable "vrack_id" {
default = "pn-1234567" #ID of your existing vRack
variable "vlan_id" {
default = "666" #ID of your VLAN
variable "private_network_id" {
default = "d111cb65-1234-5678-9012-dac2e93b8944" #ID of your private network
variable "private_subnet_id" {
default = "d8dc2469-1234-5678-9012-1f86551d3466" #ID of your subnet
variable "vrackservices_subnet_service_range_cidr" {
default = "192.168.168.248/29" #CIDR of your private network
variable "private_subnet_cidr" {
default = "192.168.168.0/24" #CIDR of your subnet
variable "mks_region" {
default = "GRA11" #Region of your existing MKS cluster
variable "mks_cluster_id" {
default = "7c3e1e6e-1234-5678-9012-4fb5a5b145e7" #ID of your existing MKS cluster
# Services to create
variable "oauth2_client_name" {
default = "efs-trident-client-example"
variable "oauth2_client_description" {
default = "OAuth2 client for EFS Trident integration"
variable "iam_policy_name" {
default = "efs-trident-policy-example"
variable "iam_policy_description" {
default = "IAM policy for EFS Trident access"
variable "vrackservices_attach_to_efs" {
description = "Whether to attach the EFS service endpoint to vRack Services. Set to false before destroying."
type = bool
default = true
variable "efs_region" {
default = "eu-west-rbx"
variable "efs_name" {
default = "my-efs-storage"
variable "efs_plan" {
default = "enterprise-file-storage-premium-1tb"
⚠️ In the file, replace the IDs, CIDR & MKS region with your existing resources information.
Replace the value of the OVH_CLOUD_PROJECT_SERVICE environment variable in the variables.tf file:
envsubst < variables.tf.template > variables.tf
Create a efs.tf file and fill it with the information:
module "ovh_efs_trident" {
source = "ovh/efs/ovh//modules/efs-trident"
# OVH region for EFS and vRack Services
region = var.efs_region
# Public Cloud region for MKS and private network
public_cloud_region = var.mks_region
# VLAN ID must be the same for vRack Services and Public Cloud private network
vlan_id = var.vlan_id
# Set to false before destroying to detach endpoint first
vrackservices_attach_to_efs = var.vrackservices_attach_to_efs
# EFS creation
storage_efs_name = var.efs_name
storage_efs_plan_code = var.efs_plan
# --- vRack ---
create_vrack = false
vrack_service_name = var.vrack_id
# --- Cloud Project ---
create_cloud_project = false
cloud_project_id = var.service_name
bind_vrack_to_cloud_project = false # Set to false if already bound
# --- Private Network ---
create_private_network = false
private_network_id = var.private_network_id
# --- Private Subnet ---
create_private_subnet = false
private_subnet_id = var.private_subnet_id
# --- Gateway ---
create_gateway = false # Set to false only if existing network has gateway
# --- MKS Cluster ---
create_mks_cluster = false
mks_cluster_id = var.mks_cluster_id # mks-priv-gra11
create_node_pool = false # Set to false if using existing node pool
# OAuth2 and IAM
oauth2_client_name = var.oauth2_client_name
oauth2_client_description = var.oauth2_client_description
iam_policy_name = var.iam_policy_name
iam_policy_description = var.iam_policy_description
# Network (shared between vRack Services and Public Cloud)
private_network_subnet_cidr = var.private_subnet_cidr
vrackservices_subnet_service_range_cidr = var.vrackservices_subnet_service_range_cidr # EFS gets IPs here
Create an output.tf file with the following content:
output "client_id" {
value = module.ovh_efs_trident.client_id
output "client_secret" {
value = module.ovh_efs_trident.client_secret
sensitive = true
output "efs_id" {
value = module.ovh_efs_trident.efs_id
The Terraform configuration is ready. Let’s init it:
terraform init
The output should be like this:
$ terraform init
Initializing the backend...
Initializing modules...
Initializing provider plugins...
- Reusing previous version of hashicorp/null from the dependency lock file
- Reusing previous version of ovh/ovh from the dependency lock file
- Using previously-installed hashicorp/null v3.2.4
- Using previously-installed ovh/ovh v2.13.1
Terraform has been successfully initialized!
You may now begin working with Terraform. Try running "terraform plan" to see
any changes that are required for your infrastructure. All Terraform commands
should now work.
If you ever set or change modules or backend configuration for Terraform,
rerun this command to reinitialize your working directory. If you forget, other
commands will detect it and remind you to do so if necessary.
Apply it:
terraform apply
$ terraform apply
module.ovh_efs_trident.data.ovh_me.my_account: Reading...
module.ovh_efs_trident.data.ovh_cloud_project_kube.existing[0]: Reading...
module.ovh_efs_trident.data.ovh_cloud_project.existing[0]: Reading...
module.ovh_efs_trident.data.ovh_me.my_account: Read complete after 1s [id=xx12345-ovh]
module.ovh_efs_trident.data.ovh_cloud_project.existing[0]: Read complete after 0s
module.ovh_efs_trident.data.ovh_order_cart.cart: Reading...
module.ovh_efs_trident.data.ovh_order_cart.cart: Read complete after 0s [id=d582ab7c-1234-5678-9012-4a6e702ea4c5]
module.ovh_efs_trident.data.ovh_cloud_project_kube.existing[0]: Read complete after 5s [id=7c3e1e6e-1234-5678-9012-4fb5a5b145e7]
Terraform used the selected providers to generate the following execution plan. Resource actions are indicated with the following symbols:
+ create
Terraform will perform the following actions:
# module.ovh_efs_trident.null_resource.config_validation will be created
+ resource "null_resource" "config_validation" {
+ id = (known after apply)
# module.ovh_efs_trident.ovh_iam_policy.iam_policy will be created
+ resource "ovh_iam_policy" "iam_policy" {
+ allow = [
+ "storageNetApp:apiovh:get",
+ "storageNetApp:apiovh:serviceInfos/get",
+ "storageNetApp:apiovh:share/accessPath/get",
+ "storageNetApp:apiovh:share/acl/create",
+ "storageNetApp:apiovh:share/acl/delete",
+ "storageNetApp:apiovh:share/acl/get",
+ "storageNetApp:apiovh:share/create",
+ "storageNetApp:apiovh:share/delete",
+ "storageNetApp:apiovh:share/edit",
+ "storageNetApp:apiovh:share/extend",
+ "storageNetApp:apiovh:share/get",
+ "storageNetApp:apiovh:share/revertToSnapshot",
+ "storageNetApp:apiovh:share/snapshot/create",
+ "storageNetApp:apiovh:share/snapshot/delete",
+ "storageNetApp:apiovh:share/snapshot/edit",
+ "storageNetApp:apiovh:share/snapshot/get",
+ created_at = (known after apply)
+ description = "IAM policy for EFS Trident access"
+ identities = (known after apply)
+ name = "efs-trident-policy-example"
+ owner = (known after apply)
+ read_only = (known after apply)
+ resources = (known after apply)
+ updated_at = (known after apply)
# module.ovh_efs_trident.ovh_me_api_oauth2_client.api_oauth2_client will be created
+ resource "ovh_me_api_oauth2_client" "api_oauth2_client" {
+ client_id = (known after apply)
+ client_secret = (sensitive value)
+ description = "OAuth2 client for EFS Trident integration"
+ flow = "CLIENT_CREDENTIALS"
+ identity = (known after apply)
+ name = "efs-trident-client-example"
# module.ovh_efs_trident.ovh_storage_efs.efs[0] will be created
+ resource "ovh_storage_efs" "efs" {
+ iam = (known after apply)
+ name = "my-efs-storage"
+ order = (known after apply)
+ ovh_subsidiary = "FR"
+ performance_level = (known after apply)
+ plan = [
+ configuration = [
+ label = "region"
+ value = "eu-west-rbx"
+ label = "network"
+ value = "vrack"
+ duration = "P1M"
+ plan_code = "enterprise-file-storage-premium-1tb"
+ pricing_mode = "default"
+ product = (known after apply)
+ quota = (known after apply)
+ region = (known after apply)
+ service_name = (known after apply)
+ status = (known after apply)
# module.ovh_efs_trident.ovh_vrack_vrackservices.vrack-vrackservices-binding[0] will be created
+ resource "ovh_vrack_vrackservices" "vrack-vrackservices-binding" {
+ service_name = "pn-1234567"
+ vrack_services = (known after apply)
# module.ovh_efs_trident.ovh_vrackservices.vrackservices[0] will be created
+ resource "ovh_vrackservices" "vrackservices" {
+ checksum = (known after apply)
+ current_state = (known after apply)
+ current_tasks = (known after apply)
+ plan = [
+ configuration = [
+ label = "region_name"
+ duration = "P1M"
+ plan_code = "vrack-services"
+ resource_status = (known after apply)
+ target_spec = {
+ subnets = [
+ cidr = "192.168.168.0/24"
+ service_endpoints = [
+ managed_service_urn = (known after apply)
+ service_range = {
+ cidr = "192.168.168.248/29"
+ vlan = 666
# (1 unchanged attribute hidden)
Plan: 6 to add, 0 to change, 0 to destroy.
Changes to Outputs:
+ efs_id = (known after apply)
Do you want to perform these actions?
Terraform will perform the actions described above.
Only 'yes' will be accepted to approve.
Enter a value: yes
module.ovh_efs_trident.null_resource.config_validation: Creating...
module.ovh_efs_trident.null_resource.config_validation: Creation complete after 0s [id=8553589333890826101]
module.ovh_efs_trident.ovh_me_api_oauth2_client.api_oauth2_client: Creating...
module.ovh_efs_trident.ovh_storage_efs.efs[0]: Creating...
module.ovh_efs_trident.ovh_me_api_oauth2_client.api_oauth2_client: Creation complete after 0s [id=EU.xxxxxxxxxxxxx]
module.ovh_efs_trident.ovh_storage_efs.efs[0]: Still creating... [00m10s elapsed]
module.ovh_efs_trident.ovh_storage_efs.efs[0]: Still creating... [00m20s elapsed]
module.ovh_efs_trident.ovh_storage_efs.efs[0]: Still creating... [00m30s elapsed]
module.ovh_efs_trident.ovh_storage_efs.efs[0]: Still creating... [03m40s elapsed]
module.ovh_efs_trident.ovh_storage_efs.efs[0]: Still creating... [03m50s elapsed]
module.ovh_efs_trident.ovh_storage_efs.efs[0]: Creation complete after 3m52s [id=c2d759de-cd63-4e28-aaab-a7599aad2ca8]
module.ovh_efs_trident.ovh_vrackservices.vrackservices[0]: Creating...
module.ovh_efs_trident.ovh_iam_policy.iam_policy: Creating...
module.ovh_efs_trident.ovh_iam_policy.iam_policy: Creation complete after 0s [id=a434d1a4-1234-5678-9012-cf54251eee52]
module.ovh_efs_trident.ovh_vrackservices.vrackservices[0]: Still creating... [00m10s elapsed]
module.ovh_efs_trident.ovh_vrackservices.vrackservices[0]: Still creating... [00m20s elapsed]
module.ovh_efs_trident.ovh_vrackservices.vrackservices[0]: Still creating... [01m20s elapsed]
module.ovh_efs_trident.ovh_vrackservices.vrackservices[0]: Creation complete after 1m30s [id=vrs-a00-b11-c22-d33]
module.ovh_efs_trident.ovh_vrack_vrackservices.vrack-vrackservices-binding[0]: Creating...
module.ovh_efs_trident.ovh_vrack_vrackservices.vrack-vrackservices-binding[0]: Still creating... [00m10s elapsed]
module.ovh_efs_trident.ovh_vrack_vrackservices.vrack-vrackservices-binding[0]: Still creating... [00m20s elapsed]
module.ovh_efs_trident.ovh_vrack_vrackservices.vrack-vrackservices-binding[0]: Still creating... [01m40s elapsed]
module.ovh_efs_trident.ovh_vrack_vrackservices.vrack-vrackservices-binding[0]: Creation complete after 1m43s [id=vrack_pn-1234567-vrackServices_vrs-a00-b11-c22-d33]
Apply complete! Resources: 6 added, 0 changed, 0 destroyed.
Outputs:
client_id = "EU.xxxxxxxxxxxxx"
client_secret = <sensitive>
efs_id = "c2d759de-cd63-4e28-aaab-a7599aad2ca8"
Save the OAuth2 credentials in environment variables:
export EFS_CLIENT_ID=$(terraform output -raw client_id)
export EFS_CLIENT_SECRET=$(terraform output -raw client_secret)
Trident CSI Installation
Install the Trident operator in your MKS cluster:
helm repo add netapp-trident https://netapp.github.io/trident-helm-chart
helm install trident-operator netapp-trident/trident-operator \
--version 100.2502.1 \
--create-namespace \
--namespace trident \
--set tridentSilenceAutosupport=true \
--set operatorImage="ovhcom/trident-operator:25.02.1-linux-amd64" \
--set tridentImage="ovhcom/trident:25.02.1-linux-amd64"
You should have a result like this:
$ helm install trident-operator netapp-trident/trident-operator \
LAST DEPLOYED: Tue Apr 28 14:01:19 2026
NAMESPACE: trident
STATUS: deployed
REVISION: 1
TEST SUITE: None
NOTES:
Thank you for installing trident-operator, which will deploy and manage NetApp's Trident CSI
storage provisioner for Kubernetes.
Your release is named 'trident-operator' and is installed into the 'trident' namespace.
Please note that there must be only one instance of Trident (and trident-operator) in a Kubernetes cluster.
To configure Trident to manage storage resources, you will need a copy of tridentctl, which is
available in pre-packaged Trident releases. You may find all Trident releases and source code
online at https://github.com/NetApp/trident.
To learn more about the release, try:
$ helm status trident-operator
$ helm get all trident-operator
Once the installation is complete, verify that all Trident pods are in Running state in the trident namespace before proceeding:
$ kubectl get pods -n trident
NAME READY STATUS RESTARTS AGE
trident-controller-5bf6c8d6f6-g95jq 6/6 Running 0 119s
trident-node-linux-4xtjr 2/2 Running 1 (82s ago) 119s
trident-node-linux-6w5ff 2/2 Running 1 (82s ago) 119s
trident-node-linux-r7hxp 2/2 Running 0 119s
trident-operator-859f59c58b-2z2ts 1/1 Running 0 2m31s
Trident Backend Creation
The Trident backend connects NetApp Trident to the OVHcloud EFS service using the IAM credentials previously created.
1. Secret Creation
Create a Kubernetes Secret containing the connection information that allows Trident to access the OVHcloud API. Create a trident-secret.yaml.template file with the following content:
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
clientID: "$EFS_CLIENT_ID" # your clientId
clientSecret: "$EFS_CLIENT_SECRET" # your clientSecret
Replace the clientID and clientSecret values by the OAuth2 client we created with Terraform:
envsubst < trident-secret.yaml.template > trident-secret.yaml
Apply the secret in your cluster:
kubectl apply -f trident-secret.yaml -n trident
Check that the secret has been correctly created:
$ kubectl get secret ovh-efs-secret -n trident
NAME TYPE DATA AGE
ovh-efs-secret Opaque 2 3s
2. Trident Backend Creation
Create your backend with the command below:
cat <<EOF | kubectl create -n trident -f -
apiVersion: trident.netapp.io/v1
kind: TridentBackendConfig
metadata:
spec:
version: 1
backendName: backend-ovh-efs
defaults:
exportRule: "192.168.168.0/24" # CIDR of your network for NFS ACLs
storageDriverName: ovh-efs
clientLocation: ovh-eu
serviceLevel: premium
nfsMountOptions: rw,hard,rsize=65536,wsize=65536,nfsvers=3,tcp
credentials:
volumeCreateTimeout: "60"
EOF
⚠️ The ovh-efs storage driver must be used. Replace exportRule, location, and other parameters with values matching your environment.
Verify that the backend has been created correctly with the command below:
$ kubectl get TridentBackendConfig -n trident
NAME BACKEND NAME BACKEND UUID PHASE STATUS
ovh-efs-rbx backend-ovh-efs ace12d67-70ea-44e1-abd8-20d016f7f030 Bound Success
Use EFS in your MKS cluster
This section describes how to expose Enterprise File Storage to Kubernetes workloads using Trident.
1. StorageClass
In a sc_efs.yaml file, define a StorageClass to enable dynamic provisioning via the Trident CSI driver:
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
provisioner: csi.trident.netapp.io
parameters:
backendType: "ovh-efs"
fsType: "nfs"
allowVolumeExpansion: true
Apply the StorageClass:
kubectl apply -f sc_efs.yaml
Check that the StorageClass has been created:
$ kubectl get sc ovh-efs-premium
NAME PROVISIONER RECLAIMPOLICY VOLUMEBINDINGMODE ALLOWVOLUMEEXPANSION AGE
ovh-efs-premium csi.trident.netapp.io Delete Immediate true 3h13m
This StorageClass allows volumes to be provisioned on demand and expanded dynamically.
2. Volume Creation (PVC)
Create a PersistentVolumeClaim with ReadWriteMany (RWX) access mode. Create a pvc_efs.yaml file with this content:
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
accessModes:
- ReadWriteMany
resources:
requests:
storage: 100Gi
storageClassName: ovh-efs-premium
Apply it:
kubectl apply -f pvc_efs.yaml
Verify that the PVC has been created with the command below:
kubectl get pvc premium-pvc-efs
At this point, the EFS is creating a volume, attach the correct ACL to it and mount it in the PVC
After a little time, the output should show the PVC in Bound state:
$ kubectl get pvc
NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS VOLUMEATTRIBUTESCLASS AGE
premium-pvc-efs Bound pvc-faca364d-ad76-44ec-9bc9-959c0d33c515 100Gi RWX ovh-efs-premium <unset> 3m43s
The volume has been created through the PVC and you can now mount it in a Pod 🎉.
Conclusion
In this blog, we’ve explained how to create an EFS and use it in a MKS cluster through Trident CSI. This will give you a flexible, production-ready approach to persistent shared storage in Kubernetes.
We recommend you also take a look at our Cloud Roadmap & Changelog for an overview of all the coming features for OVHcloud Public Cloud products.
Developer Advocate at OVHcloud, specialized in Cloud Native, Infrastructure as Code (IaC) & Developer eXperience (DX).
She is recognized as a Docker Captain, CNCF ambassador, GDE & Women techmakers Ambassador.
She has been working as a Developer and Ops for over 20 years. Cloud enthusiast and advocates DevOps/Cloud/Golang best practices.
Technical writer, a sketchnoter and a speaker at international conferences.
Book author, she created a new visual way for people to learn and understand Cloud technologies: "Understanding Kubernetes / Docker / Istio in a visual way" in sketchnotes, books and videos.
