Water cooling: from innovation to disruption – Part II
In our previous post we talked about how our water block technology evolved from 2003 to 2014. Today we continue on this theme, exploring this technology post 2015. We will focus on the current generation of water blocks, and give you a sneak peek of the improvements to come.
2015
As 2015 approached, our key objective was to design water blocks with an optimal performance of 120W and a water temperature of 30°C.
OVHcloud in 2015
In order to simplify the process and reduce costs, we replaced the metal cover with an ABS plastic one.
Introduction of ABS Plastic Covers on 2015 generation of water blocks
Using plastic covers also allowed to build prototypes without metal fittings for the input and output pipes. Instead of fittings, the pipes were directly glued to the cover of the water block.
Water block prototype with pipes glued to the cover
As with previous iterations, we also produced water blocks in smaller form factors. For instance, here you have a GPU water block:
GPU water block with ABS cover
3D printing water blocks
Using plastic covers for water blocks also opened the door to new prototyping process including 3D printing. We began to experiment with 3D printed ABS plastic water blocks, testing different types of covers.
3D printed cover variations:
Different cover configurations using 3D printing technology
Different covers using 3D-printing technology
CFD simulations
For the first time in OVHcloud’s history, we used advanced CFD (Computational Fluid Dynamics) simulations. This allowed us to optimise the thermal hydraulics of the copper-base plates, and further improve water block performance.
Redundancy
It was during this time that we first used four-tier covers, adding redundancy and improving reliability.
First tier 4 covers
First tier 4 covers
2017
We are always on the lookout for highly-standardised approaches which apply to different geographical zones’ and local customer needs. Alongside international expansion, we maintained an environmentally friendly approach, keeping ODP (Ozone Depleting Potential) and GWP (Global Warming Potential) levels very low across our datacentres.
OVHcloud 2017
By 2017 we were able to use water blocks with an optimal performance of 200W and a water temperature of 30°C and everything was fully-designed and manufactured internally at OVHcloud.
After the ABS plastic covers, it was time to test other plastics including polyamides.
Two examples of water blocks: one for standard CPUs, another for GPUs, with white polyamide covers:
Water block with White Polyamide Plastic Cover for standard CPUs
Water block with white polyamide plastic cover for standard CPUs
Water block with White Polyamide Plastic Cover for GPUs
Water block with white a polyamide plastic cover for GPUs
A water block for high-density CPUs with a black polyamide plastic cover:
Water block with Black Polyamide Plastic Cover for high density CPUs
Water block with black polyamide plastic cover for high-density CPUs
Experimenting with polyamide plastic also allowed us to quickly design and test different prototypes for enhanced CPU support and reduced cost.
Water block showing advanced Polyamide Plastic Covers Prototype for enhanced CPU support and reduced cost
Prototype of water block showing advanced polyamide plastic covers
2018-2019
At OVHcloud we have complete control from R&D to datacentre deployment. We can continuously innovate in short cycles which significantly reduces the amount of time between prototyping and large-scale deployment.
As a result, we are now more capable than ever of releasing new products to the market more quickly and for the best value. Many of our servers are delivered in 120 seconds with 100% service continuity, enhanced availability and optimised infrastructure performance.
OVHcloud 2018-2019
Over the last two years we have begun to work with a new technology, using laser-welded metallic base-plates and covers. With this technology we can avoid screws and glue, and minimise the risk of leaks.
Cutting-edge generation of water blocks
On these water blocks, piping is done entirely using copper-welded tubes.
Piping using copper welded tubes
As usual, we also build water blocks for specific form factors, like GPUs or high-density CPUs.
Water block for high-density CPUs
Water block for very high density CPUs
2020-…
At OVHcloud we continue to identify, transpose and adapt what works elsewhere to allow us to innovate and create our own solutions. We will follow disruption cycles in order to increase efficiency and reduce costs, always striving to create added value for our customers.
We are working on the next generation tier-4 water blocks, with our patented technology. Our tier-4 water blocks aren’t a prototype anymore, but prod-ready, and we are working extensively with simulations and tests to improve performance.
The next generation Tier 4 water blocks
(under prototyping and testing)
We are aiming for water blocks with a performance of 400W with a water temperature of 30°C, with a fully-redundant water supply.
Next generation water blocks... to be revealed
Next generation water blocks…
to be revealed
And besides water blocks?
At OVHcloud we hare proud of our R&D laboratories. They are fully-committed to pushing our competitive advantages on hardware, software and our custom-proven methods of server stress validation and testing. In our labs, we design and test cooling solutions, new server prototypes and innovative storage options.
In future posts we will share other aspects of our industrial innovation process, and look at how our customers benefit from the continuous improvement of service reliability and the price efficiency it generates.
Ali Chehade
Ali Chehade is Head of R&D for Cooling Systems at OVHcloud, where he has been leading the company's thermal innovation strategy for over 10 years. He architected OVHcloud's proprietary liquid cooling and has contributed to more than 100 patents, helping the company achieve some of the lowest PUE and WUE metrics in the cloud industry.
His work focuses on making high-density and AI computing sustainable - eliminating water waste, reducing energy consumption, and enabling heat reuse at scale. He is currently driving next-generation innovations including AI-driven thermal intelligence and immersion cooling for future infrastructure.
Linkedin Profile
