Remote development #3 – Industrialisation and Automation
After manually configuring your server step by step, it’s time to automate the entire process.
The idea is simple: describe your infrastructure in configuration files and let Terraform take care of managing the resources at OVHcloud.
Here is an introductory guide to Terraform, with plenty of useful information: https://support.us.ovhcloud.com/hc/en-us/articles/22648864003219-Using-Terraform-with-OVHcloud.
As well as the link to OVHcloud’s official Terraform provider: https://registry.terraform.io/providers/ovh/ovh/latest
There are two steps to automating the deployment:
  • Deployment of the Public Cloud instance
  • Deployment of the application part (vscode-server) and its configuration
1. The heart of the automation: the Cloud-init script
Before we move onto Terraform, we need to understand how the server self-configures during its initialisation.
To do this, use cloud-init, a standard that allows scripts to be executed from the first boot of the instance.
What you will automate in this script:
  • The system update (apt update/upgrade)
  • The installation of code-server via the official script
  • The installation and configuration of Caddy (for automatic SSL)
  • The configuration of the Uncomplicated Firewall (UFW)
This type of file has a very particular syntax; the cloud-config.yaml will be available further down.
However, the important point to remember is: why use this format?
  • Idempotence: cloud-init ensures that everything is ready from the first boot.
  • Security from the outset: the UFW is activated immediately, reducing the exposure window.
  • Terraform Integration: a single line is required to include this: user_data = file("cloud-config.yaml")
2. Using Terraform for deployment
Terraform allows for a much easier and quicker instance startup.
Its configuration also has several advantages:
  • Persistent data: a terraform destroy of the instance can retain the data volume (goal set in chapter 2)
  • Scalability: if the project grows, the size of the volume and/or the flavour can be adjusted
  • Portability: the data volume can be unmounted and remounted on another machine.
To keep this post brief we won’t copy-paste the code here, but this link to a GitHub repository contains everything needed to deploy this in a few minutes:
https://github.com/RemyAtOVH/blogpost-dev-server
Its usage:
uubuntu@vscode-server:~$ source openrc.production.sh
ubuntu@vscode-server:~$ terraform init
ubuntu@vscode-server:~$ terraform plan
ubuntu@vscode-server:~$ terraform apply
Apply complete! Resources: 4 added, 0 changed, 0 destroyed.
Before applying cloud-init (or without it), there is a secondary volume /dev/sdb, sized according to Terraform specifications:
ubuntu@vscode-server-automated:~$ lsblk
NAME    MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
sda       8:0    0   25G  0 disk
sdb       8:16   0   10G  0 disk
This is what will ensure data persistence.
You could manually delete the instance and other components, without deleting it.
To prevent any deletion in the event of “terraform destroy”, a parameter has been added:
lifecycle { prevent_destroy = true }
During the first startup, the various installation scripts may take time. You can check their steps with a simple tail:
ubuntu@vscode-server-automated:~$ tail -f /var/log/cloud-init-output.log
Once cloud-init has been executed automatically, everything that could have been set up manually in the previous chapters has been done automatically, in a way that can be reproduced!
It will therefore be possible to deploy this customised remote development environment if needed (with a few minutes of execution) and potentially delete it after a few hours or days of use.
In this series of chapters, we have transformed a simple idea – having access to VS Code wherever you are – into a professional-grade, automated and resilient infrastructure.
Below are the steps involved and the progress so far.
  • Chapter 1: first steps in manual installation to understand the mechanics of code-server.
  • Chapter 2: making it secure, using a Reverse Proxy (Caddy) and a firewall (UFW) to navigate smoothly in HTTPS.
  • Chapter 3: this article, in which we’ll use Terraform and OpenStack for better reproducibility.
The automation we have implemented with an OVHcloud deployment using an OpenStack-based Public Cloud provides a solid foundation.
From here, you can go even further: add automatic backups of your volumes (snapshotting), couple this with a CI/CD pipeline, or even explore deploying this environment via docker-compose or even Kubernetes.
A step-by-step video version of these blog posts will soon be available on our YouTube channel. Stay tuned!
Rémy Vandepoel
Let's talk servers, instances, containers, and the magic we can do with them!
